amstrad
hello i have a 134 cubic inch engine out of a 601 ford tractor. it has been setting up a long time and is stuck. I have not been able to free it up would like to know the best way to do this. DJ
DJ:
You cannot determine the best way to free your stuck engine without partially disassembling it.
More than likely the valves are stuck in the valve guides and/or the lifters are stuck in the bores. As a minimum you will need to remove the rocker arm cover and tappet cover to determine if this is the case.
If you determine that ALL valves and lifters are free, post back for further advice.
Dean
like dean said, pull the valve cover for a look see. i would also drain the oil out of the motor and take a look at it for water and or anti freeze. it will give you a hint about what you are up against. pull the spark plugs and fill the cylinders with a mixture of 50/50 automatic transmission fluid and acetone, or buy a gallon jug of pb blaster and fill with that. also, get the mix on the rocker arms and valves too to get them loose. i put a drain pan under the motor and leave the oil plug out to see when the oil starts to pass thru the rings and drip into the crankcase. at that point you can try and bump the motor over. prolly be a good idea to drop the oil pan and check the main and rod bearings too.
The way I do it and I do a lot of them is this. I fill the cylinders with ATF and walk away from it. Leave it sit that way for a week or more. Always put the plugs back in to keep dirt etc out. Now for a question or 2 is this engine in a tractor?? If it isn't then it will be harder to free up because it is not mounted solid to some thing. If it has the flywheel on it then you can use a bolt and pry bar to see if you can move it. When I have one like this I try to move it back wards so that it backs off of what has it stuck or at least in theory it does. And yes while you wait you can put the valve cover and see if the valves are stuck
Amstrad, This is the easiest and most simple way to free up a stuck motor, I know of!!! As Dean said you will need to partially disassemble the motor...
Remove, gas tank, intake/exhaust manifold, head, and pan. Also remove and mark each rod cap too! At this point it should be obvious to which cylinder is stuck (signs of rust on the top of the pistons)
Remove all flammables from the area, roll the tractor outside, fill the cylinder that will hold the most liquid by volume with Diesel and add a splash of gas, set the mixture on fire, Now sit down and drink a cup of coffee after the fire burns itself out drive the piston out from the bottom. Now start on the next piston and start the process over. On the pistons that are near TDC you may have to fire it 2,3,4 or more times to get the rust to break loose.
You should be able to do a 4 cylinder motor in a 2 or 3 hrs in most cases, Usually there is only one piston that is really stuck, the others usually have light surface rust, You should usually be able to save the pistons in most cases.
Hope this helps.
Later,
John A.
Guess everybody's got a different take on this. I'd take off the valve cover and make sure valves are free (loosen rocker arm assembly, use vicegrips on rag-wrapped valve end to see if you can move it up and down). If they're free, remove plugs, pour in 50/50 acetone and automatic tranny fluid. Leave plugs out so you're not fighting compression (put strips of rag into each plug hole to keep crud out). Put tractor in gear, and every time you walk by it, give the rear wheel a little nudge, forward and back, to see if it moves.
John A's method is kind of a last-resort deal- much better if you can do it without resort to violence.
Mike, I must question your defination of violence! When one breaks out the 4x4 block, a 5 lb sledge hammer and cheisel and the piston starts comming out in pieces is the violent approach IMO.
I an taking about simple disassembly of an engine, and overcoming the stuck pistons with heat/fire. I have seen engines that have been stuck for yrs taken completely apart in an afternoon with this method and the pistons were reusable after it was done. Depending on the amount of water that was in the engine and how long and often it sat in water.
Simply Rering the pistons and Hoan the liners if they weren't rust pitted, would have worked on a few but it is still better to know than to guess on the internal condition of the engine.
My premise is there is usually a reason the tractor was parked to begin with and the engine later stuck and the tractor finally was abandoned is some fence row. So the engine needs to come apart and be looked at!
Later,
John A.
