Studebaker Truck stalling
JimS
We have several Studebaker trucks at the ranch. Im told this is an AA model. We were planning on taking it to a parade Sunday, but it stalls when braking hard or braking hard going downhill.
My coworker theorizes a carburation issue; that there is a problem with the floats. Its all original.
Is he on the right path? What might be other causes?
Thanks.
An ignition wire could be broken causing a disconnect internally when braking. Usually fuel issues happen 30 seconds or more after braking/hill happens. if it delays then it coud be fuel. Either tank obstruction, or float. Make sure the carb is not loose on the manifold. Jim
