Mnethercutt
Having what I think is a fuel issue w/ my 1010 gas. Tractor tends to stumble and backfire when I accelerate. I can improve or worsen the problem by adjusting the fuel mix on the carb. If I open the adjustment the stumble is better, but the tractor runs rougher and has a little black smoke out the exhaust. Exhaust also smells strongly of gas which makes me think it's getting too much fuel. If I screw it in the tractor runs stronger (at least it sounds stronger) but backfires a lot and almost dies when I try and accelerate from idle.
I've really only tried adjusting that fuel screw, but what do you guys think? Should I just let it run a little rich but backfire less? Got fairly new plugs in it, not sure about status of the points. Engines out of a power unit so it just ran at a constant speed when I got it.
Thanks a ton guys.
Thanks a ton guys.
