Deere guy here working on an 8N sidemount. My aunt got it hot and cracked the head and the block. She found me a used block and a rebuild kit and I got the sleeves in it. Valve train is in. Problem is with the crank. I can torque the front and middle main bearing caps and it's fine but as soon as I torque the rear cap it locks up so tight I can't turn it with a breaker bar. The crank has been turned .010 under sometime previously and I have .010 bearings. I reused bearings from the old motor. First I put all caps and bearings back where they originally were. Tight. Then I tried caps that came with the block then bearings in different places. Every combination I could and it's still tight. I used green plastigauge on the rear main and clearance is .0015, in spec but on the tight side. Everything I have tried is without other caps on, just the rear one. No burs on any bearings or crank. I'm at a loss on this one. Aunt is getting anxious cause the grass is growing. What in the world would cause this crank to tighten up like this? I'm about to order new bearings and try that based on what I hear here. Thanks for any help. Getting frustrated.
