Sub soil as deep as possible. Even go 2 or 3 times to get deep. Then go cross way if possible. The slots will allow water to drain. Sub soiling will not disturb top soil. Again, it takes power to pull deep.
On plowing "cross ways" on subsequent passes, Assuming making a +...... I never liked to do that. I found that Xs are a lot more comfortable.
I'm with Paul. Let the crops loosen up the clay. Taproots such as radishes, alfalfa, cereal rye, etc. will break it up. The ground just has to be worked enough to get the plants to germinate and grow.
Thanks Paul and Bill
That makes me feel much better
Plan is to scarify as deep as I can to give the plants a head start.
LSU did a study that showed the radish rye grass mix did not do as well when overseeded in a grass pasture as it did in cultivated crop land.
I have daikon radish and annual rye grass seed already.
Also got coated & pre inoculated balansa clover on the way
This clover was more expensive per pound but less per acre and deals with low PH better
I recently put down high mag lime per soil test but it will take months before it does any good
We will see how it goes but my plan is to mow this down and plant a cowpea (for the nitrogen) sunflower and sorghum sudangrass mix next spring.
Sorghum sudangrass is a cousin to johnson grass without the problems because the seeds are sterile.
All these cover crops are suppose to have deep roots so maybe by next fall I will see some improvement in this soil
