I'm with Paul. Let the crops loosen up the clay. Taproots such as radishes, alfalfa, cereal rye, etc. will break it up. The ground just has to be worked enough to get the plants to germinate and grow.
Thanks Paul and Bill
That makes me feel much better
Plan is to scarify as deep as I can to give the plants a head start.
LSU did a study that showed the radish rye grass mix did not do as well when overseeded in a grass pasture as it did in cultivated crop land.
I have daikon radish and annual rye grass seed already.
Also got coated & pre inoculated balansa clover on the way
This clover was more expensive per pound but less per acre and deals with low PH better
I recently put down high mag lime per soil test but it will take months before it does any good
We will see how it goes but my plan is to mow this down and plant a cowpea (for the nitrogen) sunflower and sorghum sudangrass mix next spring.
Sorghum sudangrass is a cousin to johnson grass without the problems because the seeds are sterile.
All these cover crops are suppose to have deep roots so maybe by next fall I will see some improvement in this soil
I can understand where chiseling soil allows more rainfall to stay in soil rather than running off.
In thread starter post, John in la said " If you drill down a foot or so to install a fence post you have to beat the clay off the shovel because it gets so wet."
I'm having trouble understanding is how chiseling promotes oversaturated soil to dry out. To me it sounds like all that's needed is more organic matter in surface.
I’m hoping the chiseling will allow water to drain laterally. Basically I’m trying to tile the land with a chisel plow.
The chisel groves will also allow the cover crop a head start as it pushes roots down by giving cracks rather than hard compaction to dig into.
I’m not trying too add 6 inches of organic matter on the surface I’m trying to add organic material into the top 6 inches of soil.
If you guys think a box blade with the teeth down will be enough I’m all for skipping the chisel plow part.
