Super 55 carb adjustments
Spikec65
I have an '57 Oliver Super 55 with a Marvel Schebler carb. I got the Idle, timing and governor set correctly (I think, maybe not) and it starts right up and idles great but I'm having issues with going to full throttle, if I open it up very slowly I can get it to full speed but if I go too fast it coughs stumbles and dies. I know I'm missing something. Does anyone have any advice?
I don't know about to 55. Does it have the nob to increase the fuel flow, if it does, open it a little. If it has one it'll be at the bottom of the carb.
Thanks, I double checked, the Schebler only has 3 adjustment screws, idle speed, idle mixture and high speed load but your suggestion makes me wonder if I have the float set correctly and there's not enough fuel in the bowl for the demand, also I forgot to mention mine is a top main jet carb they also made a bottom jet version.
Thanks again
Thanks again
U need to watch Ross the Oliver man, on YouTube
Lots of carb info from him.
GG
Usually stumbling on acceleration is the idle mixture is a little lean. On most MS carbs the mixture screw actually controls the air, not fuel, so turn it in to richen.
