Super 55 PTO does not engage
Luxpatriate
I bought my first tractor. A fairly sorted out early Super 55. The first attempt to shred brought to my attention that the PTO is not right. I adjusted it many ways, but nothing worked. I notice that it is very easy to move the PTO lever. I think it is supposed to have some amount of pressure required (30 lbs or so) to engage. Mine takes zero pressure and also does not engage or is always slipping. Time for a new clutch? Do you have to split the tractor to change the PTO clutch. Any guidance is appreciated?
What did you try to adjust? You have to take the inspection cover off underneath, then reach up in from the bottom to tighten the clutch plates.
Yeah, I have seen this video and another, but it wasnt helpful. I adjusted the clutch in the very direction up to just before that crown nut wants to come off. I never reached a spot where it takes any effort (mush less 30lbs) to engage the clutch. Perhaps I have missing parts or destroyed fiber plates. I plan to rebuild the clutch pack based off of another video I saw.
Yes. I depressed the pin and turned the crown nut clockwise and counterclockwise and tested at various settings. Never does my engagement lever (from the cockpit) ever become necessary for 30lbs to move the lever. Perhaps some fiber plates are gone. Clutch pack rebuild likely required and based off another video I saw from the Canadian redneck it looks like it is not too bad if a job.
If the nut is about to come off when you're adjusting it, you're turning it the wrong way. It turns clockwise to adjust it. HTH, Kent
Watching that video, I think it would be easier to Z split the tractor rather than have to remove the steering wheel, the dash requiring the wiring has to be disconnected & the pitman arms to be able to remove the steering box,. Then have to remove the top half of the bell housing. Splitting it would enable you to replace the seals on the PTO drum which I would highly recommend. HTH, Kent
So if I am splitting the tractor...do I go ahead and replace the drive clutch too? I have not noticed an issue with it, but splitting a tractor scares me (perhaps unnecessarily).
They're a simple split.
If you havent had trouble with drive clutch , I wouldnt mess with it. Its not a bad split, get you a shop manual if you dont have one. Every time Ive had one that wouldnt adjust to snap in, its been in the discs.
It's easy to split. just need some jack stands and a rolling jack is handy. I think I have had mine apart three times. LOL.. still leaks. One on of the splits was by a shop.
(quoted from post at 13:21:22 05/10/21) Watching that video, I think it would be easier to Z split the tractor rather than have to remove the steering wheel, the dash requiring the wiring has to be disconnected & the pitman arms to be able to remove the steering box,. Then have to remove the top half of the bell housing. Splitting it would enable you to replace the seals on the PTO drum which I would highly recommend. HTH, Kent
Kent,
Good news. I have retrieved my tractor from the farm, ready to start the Z Split. Will download the I&T manual today as well. Can you confirm that this is the correct seal kit and that replacing the seals once the split is done is a bench job that does not require any special tools, etc?
https://external_link.com/pto-seal-kit-super-55-550/
Thanks,
Ash
