Super 66 questions
I'm thinking about purchasing a
supposed super 66...it has a
super 66 belly but I'm not sure
about the rest. What are the
casting or serial numbers for
the engine block and what is the
diameter of the rear axles.
please help
   I have a Super 66 and two 660s.  The Super 66 has a crankcase w/LB 100B as does the early (59) 660.  The later 660 has #104 307A casting number.   Both are gas.
   Lay down under the transmission case, there are raised numbers that is the date the casting was poured, should be within a month of the build date (last number will be the year).  Another easy way to determine transmission is the rear axle hubs.  66 tractors had L 704 wheel hubs and Super 66 & 660 had L 704A hubs (number is cast on hub).
