the nebraska test weights are not always accurate as sometimes they put several set of weights on or put fluid in them.
Stock weight wet with no driver is about 3300lbs. They will pull a 3500lb class, but probably not 3000lb.
I've seen a couple 66's in the 3000lb class, but with not much room to spare at all.
Zack
they state in the test whether it has weight or not. and it weighs 3495 with pressed steel wheels the other was with iron .
Theres a Super 66 in Southern PA that I Pull agenst with my Farmall BN that will get in 2500lbs But it as Striped as you can get!
Cliff S
here's that 66
