Super 88 electric PS
Ohio88
Location
Fairborn, Ohio
As requested here are pictures of the electric power steering on a Super 88
A bracket was made to keep the unit from trying to turn. Another Bracket for the control unit.
The motor is wired to the battery through a 50 amp fuse. I have not seen it use more the 20 amps.
The control unit is powered through a switch. No other electrical connections were made.
This is the upper shaft, welded the KIA shaft into the upper universal.
This photo is how the control unit is mounted, there is a home made bracket to hold it.
The bottom connection with the stub of Oliver shaft welded in to the coupler from the KIA.
How the tractor looks with the skin on.
How the unit sets in the tractor.
Thanks for the photos. That's a cool setup. I assume you're not concerned with dirt and dust since I see no insulation on the connectors, and that tractor is far too pretty to work. Looks great.
Very neat setup, I'm interested in putting one on our 770 and an 880....
where did the nubbin clamp come from that is spot welded to the stub Oliver shaft,
right below the operator motor? Then this same nubbin clamp is tightened to the operator shaft
with the threaded bolt, correct?
And this is Kia as in the car parts?
Thanks so much for sharing pics and ideas. that is so awesome on here! GG
That is a REALLY nice, clean install!
Where did you find info on the basic electrical connections required to make the KIA unit operate?
The power steering came from a KIA Soul out of a junk yard. The numbin came with the steering column. It is welded to the a shaft that was on the Oliver and slides onto the bottom of the motor. The wiring I start on the internet, and went from there. It is fairly straight forward.
Now the reason for a KIA Soul was research said it was one of the heaviest on cars from the east.
Why a one for the east. If you use one from an American car you have to supply a speed sensor input, which can be done with another module from internet but it is another $90 to $120. I got the whole column and sold most of what I did not use. I think I have less then $100 in it.
On 770 or 880 you may have to check for room. You can use other models that are small. Toyota Prius is one you can use.
As near as I know it has to be pre 2012 as after that they changed the setup.
Thanks for posting this, I'm going to print it off so I have it and then start looking for a Kia Soul at the junkyard. Chris
(quoted from post at 14:53:28 12/02/21) I found the wiring info on the internet. I will see if I can find the diagram in the shop and post it.
Thank you, that would be AWESOME!
Based on the info that the writer provided about the fail-safe mode without an ECU, is the controller shown in Ohio88's pictures needed? Or is that a different controller
than the ECU.
(quoted from post at 09:34:32 12/07/21) Based on the info that the writer provided about the fail-safe mode without an ECU, is the controller shown in Ohio88's pictures needed? Or is that a different controller than the ECU.
The ECU is needed for making the unit work. It looks at the difference between what the steering wheel is asking for and the position of the output side of the steering shaft, then applies a suitable amount of torque via the electric motor to make the shafts align. If the ECU fails, the input and output shafts are still mechanically coupled to provide manual steering through the box.
Hope that helps
