Super 88 lost hdys
old
So my S88 sat pretty much for a year with out being used. Seems it has lost hdys for some reason. Fill with fluid and give it a few minutes and well it appears you didn't add any fluid. My thinking is the shaft seals have gone bad again. Is this a common problem with Olivers?
Pump seals do go bad and you will most likely see the lost oil down in the transmission via a raised oil level. Pump most likely needs a rebuild while you are at it.
