Super 90 steering parts
B Reimer
I tried to order the tie rod with the tube attached for a 90 WR and was told it is discontinued. I know there will be other tractors and trucks that use the same size but don't know which ones. This one uses a 13/16 fine thread rod in the tube. Does anyone know what else will fit? I can get aftermarket ones like "High Capacity" but they are the teflon type and don't last for more than a year or so. I don't mind if I have to cut the old joint off and weld a new end to my pipe. I have used truck joints on my bigger tractor and they are much more durable than the OEM for the tractor. Thanks
Bruce
A 165, 175, 180, should also be the same. 1080 and up it is a larger size tube. If you don't have any luck there, Worthinton ag parts (Worthinton MN location) scrapped out a couple Super 90's a while back.
Good Luck
Merle
