Super A C113 timing gears
BT73000
Working on my 50 SA, removed oil pan when I bought it to clean before use and found metal filings and a worn crankshaft and hydraulic oil pump gear. Ran approximately 5 hours this summer and removed pan again to inspect and found more filings in the oil pan. So, removed the front end and gear cover to inspect further. Crank gear looks to be badly worn as well as the hydraulic oil pump gear which is no surprise cause I noticed that last time the pan was down, but the cam and governor gear don?t look as bad, though I can measure around .050 backlash between the gov and cam gear. Is the wear on the gear train on these tractors common and would just replacing the crank and pump gear be sufficient? I know the old gears fill wear the new ones, but really how fast considering 5 to 10 hours a year. Also found the governor thrust bearing cage and balls wrecked when I removed the governor housing. Some of the metal from this failure may have caused some of the gear wear. I also used 15/40 rotella oil this summer and that could have loosened up some laid out metal filings and washed them down to the pan this time for the second inspection. Looks like it?s going to run around $450 to replace the four gears with aftermarket parts.
there are no aftermarket parts they will come from I-H.check the input shaft on the hy pump as some forgot to bend the washer holding the gear from coming loose I have the gov gear and a good cam gear and should have a gear for the crank I will look for it tomorrow if you are interested I need to know before Wendsday as I am leaving for Buffalo,NY for a week. call 319-430-3907
Thanks for the reply Gene. I'll give you a call tomorrow.
