Super A carburetor
BT73000
I have a 1950 SA with a Carter UT on it. It has a broken mounting ear where it connects to the manifold. I would like to fix this issue and have found a used zenith carb from a Farmall C. Will this carb interchange without any modifications? Thanks
Engines are basically the same, if I remember right, both had the 113 cubic inch engine. C's didn't get the larger 123 engine until they became "super sized". Although they were called "Super A's", they never got the larger cubic inch engine until the last 500 or so. These had the Super A-1 designation on the tag. If that's not correct, I'm sure someone will probably let us know.
