Super A crankshaft
Nickc711
I am sending my crank to the machine shop to get re-ground, what info/parts do i need to give them, i got the i-t manual but im unclear if the measurement in the front of the manual is the minimum diameter or the actual diameter
The measurement is as it came from the factory. Let the machinest order the bearings so that you can be assured that he can get the ones to compensate for the amount he needs to machine off. In other words let the machinest make the decisions and don't order the bearings ahead of time.
Are you dealing directly with the machine shop or dropping your crank off with a local shop tht will job it out? An idle question really. Last one I had ground, it was closer to the shop with the lathe than to the nearest jobber. I took it there myself.
Was pretty impressed. He asked wht it was out of, and went straight to a manual about the size of the MAnhattan white pages, and looked up the original specs to match the part number on the crank. Pulled a mic out of his pocket and went across the rods and mains. Told me tight off bat that it was worn enough that he knew he could turn it down .010 but might not be able to polish it, might have to go the whole .020. He made a point of looking at the shaft to see if any machinist had turned it down before, and left a mark to indicate that, the same kind of mark he left when he was done. Just like watch makers used to engrave the date of every cleaning or adjustemnt under the back cover of the watch, these guys stamp into any crank they work on how far they have turned it down, with codes for the rods and the mains.
The specs in the I&T are for new/factory.
Just tell what it's off of and they will look in their manual as been suggested and have them furnish the correct bearings. Hal
