Super A lifting arms
Younger
Are the lifting arms at the rear of the tractor supposed to be the same height off the gound or offset? Looks like they were welded at one time and are not parallel.
Younger: Randy is correct they should be the same. You say parallel, do you mean parallel to each other or when one arm is parallel with ground, so should the other arm be parallel with ground. I'm thinking that is what your driving at.
If you're talking about the front of the arms (toward the front of the tractor), yes they should be the same height.
The rear of the arms should also be the same height but there should be an adjusting screw to raise one up or down until both are the same height.
looks like some hack welding job. They are about 35 degrees different. I will try to post some pics to solicit some advice as to what to do.
If its real bad you might find one to replace it with easier than straightening yours.
Heres a pic showing mine. The right hand side was bent a little but I had it heated and straightened out. Still has a little crook to it if you look close.
