super a manifold qestion help
susan A
i need to know on how you can get blaster (flammable liquid) off of the manifold i had it siting on top of the hood and started the tractor up and about the time i jumped to reach it i hit the button on top then it had shot some of it on to the manifold!? what should i do??????? is there way i can keep the manifold thats on now or have to get a new one?! thannks for your replys
Do as Jim said fire it up and let it smoke. Do watch just in case it does try to start a fire and if so put it out. As for any real harm you have done nothing that will hurt a thing since when a valve cover gasket gets bad it will drip oil on the manifold any how
Just reminds me on a diffeernt tractor, [H] , I installed a small A-B-C fire extinguisher on the side, back by the 3-point hitch. Justi n case. NOt saying you're in danger here, but if it ever did catchon fire, youj'd be able to stop it quick.
(quoted from post at 12:37:41 03/12/13) i need to know on how you can get blaster (flammable liquid) off of the manifold i had it siting on top of the hood and started the tractor up and about the time i jumped to reach it i hit the button on top then it had shot some of it on to the manifold!? what should i do??????? is there way i can keep the manifold thats on now or have to get a new one?! thannks for your replys
Just fier it up. It will smoke a bit.
