Super A Mid Mount Mower
marvintj
Just picked up an IHC mid mount mower that came off a Super AV. There were a number of small issues with the mower that I am fixing once I got the mower home last Saturday. There are two issues that are not totally clear on this, maybe three.
1) Model number- the tag is painted over and I have not tried to clean it off to find out the model number so that I can order a manual for it. Ideas on model?
2) The mower bar has the holes for the bracket to hold the bar vertical in transport mode. However the bracket is not there for holding the bar in a vertical position. It is not clear how the bracket would mount and where the bracket would attach (business end) when using the mower. Any ideas or pictures?
3) Currently there is an added eye bolt that is being used for adjusting the rotational position of the mower relative to the ground. The eye bolt is an add on by the previous owner and I do not think that this is what was there from the factory. Doe anyone have a picture or a description of what the hardware looked like or how it mounted on the mower?
4) The large pulley (guessing about 12 inch) that goes on the PTO shaft was bent when pulled off the Super AV. The pulley is made from two pieces of heavy sheet metal that are stamped to shape and then bolted together to form the vbelt pulley. One piece of the sheetmetal is welded to the splined hub. Has anyone ever been successful in straightening anything like this? How did you do the straightening.
Lots of questions, hopefully lots of good answers.
