Super C 3pt
jeffalex2
I want to add a 3pt to the Super C so it can share implements with the 2N. Currently it has a fixed drawbar and working touch control with rock shafts. Is the kit sold here good?
Thanks
You get hant you pay for. How much heavy work will you be using it for will depend on how strong of a unit you are willing to pay for. Some are much stronger than others.
I haven't looked to see what brand this site sells. I'm a get what you pay for person. The best brand is Saginaw, last time I looked it was about $700 plus shipping. It is stronger than the tractor. In other words if you overload the 3 point the Super C will give up first. They are that good. They use a hyd cylinder, you don't want one that uses the rockshafts. They will sell you a modification "kit" that includes a bypass block and a valve to raise and lower it. You supply the hoses. You also need the factory clamps on the axle to bolt it to.
