Super C C20 plow moldboard
Dean Olson
I'm working on a Super C, C20 2 point 2-14 fast hitch plow. The mold board is broken, part # 515710R1 SCO. I hate to weld this one up. The other mold board part # is SC 515710R1. They look the same is there any difference?
Anybody have one or a know of a source for one?
its not that hard to weld moldboards.
I have successfully welded moldboards,its not that hard.I have plowed hundreds of acres with a welded moldboard.
With a 6-digit part number in the 515XXX range I am thinking that's a Plow Chief moldboard. Unfortunately, you've got a tough row to hoe to find a good replacement.
That is a 14 inch Plow Chief board. The numbers are the same so they are the same part. I have thought that SC stands for soft center so I don't know what the SCO stands for. Plow Chief is pretty common, should be able to find something new or used. Try your dealer or depotparts.com.
CIH dealer can get a new one for a whopping $267.00 Yikes!!
I have found a Super Chief 2 point plow that I can buy for parts. The guy that has it can't find any #'s but says it looks the same.
Are those the same moldboard?
(quoted from post at 12:04:14 03/24/10) CIH dealer can get a new one for a whopping $267.00 Yikes!!
If it is indeed Super Chief, no they are not the same. One thing to be aware of, there is a Plow Chief board with a replaceable shin. Same thing, just with a replaceable shin. I think he better come up with numbers to confirm what he has.
If the junk plow has 2 good Super Chief bottoms, you could move both bottoms onto your C20. Parts for Super Chief bottoms are easier to find.
