Bohn Super C
I have a 1954 Farmall Super C tractor that has been converted to a 12 V system. The tractor was starting right up and running smooth, but after I ran it while the tractor would up and quit, just like somebody turned the key off. ( Someone replaced a push pull button with a key when they converted the 12 Volt system before I bought it. ) Sometimes I will pull the starter lever and it will start right back up, and other times the engine turns over good, but I have to turn the key off then back on again before it will start. Last time I used the tractor is started up but it ran terrible, like it's not running on all four cylinders. I was wondering you think it could be a bad coil acting up, or points and condenser, or maybe even a bad key switch? Any comments would be appreciated thank you.
