Super C Distillate Carb
GaryinAL
Hello all, I have a 1951 Farmall Super C that is a Distillate model. I am wanting to put a carb kit in it, but I can't find any info on the carb that is on it. It has UT 0-1177 stamped on the bowl and 0-1397 stamped on the mounting flange. I have searched the internet for any of these numbers, hoping that I could find the carb kit I need. IHCASE shows the part number as either 373961R91 or 356902R92. Anyone know where I could find info on this carb, or a kit for it?
Any help is appreciated.
I believe UT is the designation for Carter -- so get a kit from CaseIH for a Carter carb. The kit likely contains parts for both distillate and gasoline, unless the parts listing says otherwise. To be sure you have the right carb look at the bowl or bowl gasket and compare it with the diagrams.
