Super C duals.
jonny-o
I have the long style rear axle on my Super C. I want to mount my dual tires on it. Do I need to turn the rim around on the outside tire and also will my weights stillm mount up?Thanks
Never seen duals on a Super C, but i would dish the inside one in, and the outside out, so you can maximize the space between the tires,to keep the mud/dirt from sticking in their. As far as wheel weight's i would put them all on the inside wheel, to keep it closer to the bearing! And if you drive on a section line,]any ruts] keep the weight of the tractor on the inside tires if at all possible !
I have duals on my Super C and I like them. I used the regular spacing, and as fastfarmall said it
occasionally gets some mud stuck between the wheels. I wound up with about 2" between tires.My
weights are on the outer wheels. My thought was that I could remove the outer wheel for mowing, thus
removing the most weight. I since have added a 200 to my collection that I use for mowing, so I don't
have to wrestle with the wheels.
If the bearings are centerd to weights yes. Now if the weight is sideways from bearing it will want to move pressure on bearing from every reveloution of wheel. Same reason a shaft will bend sticking past the supporting bearing.
