Hi guys i have a early 50s super c with the 12 volt electronic ignition system that will not start it cranks up and will not start have fuel and the coil is hot to the touch but if you pull the kill switch out to turn it on it just cranks but if you move the button for the ignition kill it try's to start have replaced the switch and cleaned the block surface were the starter mounts cleaned the ground if you move the button to kill the engine it trys to start as if the button is supplying power to the starter. battery with jumper cables on do it has full voltage someone said the wiring is not right but has been running for the last couple of years this way
