Super C hydraulic setup
Hello everyone! I just picked up a 52 super C in great shape. I love the tractor and mainly will be using it for mowing the fields. My problem is this tractor came without any of the hydraulic attachments. It had the pump and the box/arms but thats it. I want to put either a fast hitch or a 3 point hitch on it. I've looked everywhere online but can't find any good pictures / Parts diagrams of what this tractor is missing. I'm hoping someone on here either has a very detailed parts diagram or would be willing to take a bunch of pictures of their set up so I can figure out what I need to be looking for. Also if anyone in the st. Louis area has to set up for sale at be interested. Thanks for all your help guys
I've got some of that equipment (more than I need)
plus a Fast Hitch system. Willing to sell at a very reasonable price.
Call me at 660-882-6579 at Boonville, MO.
What kind of a mower are you wanting. You are going to spend a bunch of money which can get expensive quick just for the hy system
I don't know if this is what you need, but mine is a 53'.
You don't specify what type of mower you plan to use which could certainly clarify things a lot. If you are just wanting to clip tall grasses and weeds in summer time to keep the fields looking nice a bush hog or trailing rotary cutter sized to your Super C wouldn't require any additional hydraulics other then what you already have. Most of that type of cutters have adjustments on the mower itself to control height of cut and additional tractor hydraulics wouldn't be required. If you want to continually vary the cutting height for various reasons, yes tractor seat hydraulic control would be nice to have. The photos already provided by Rick are very complete except for the left (clutch) side as there is an adjusting link between the left side rockshafts on the hydraulic unit under the fuel tank which runs back to the hitch on that side of the tractor. I call that item the leveling link and is used to tilt one side of the fast hitch implement up or down. I have a 1953 Farmall Super C with the two point fast hitch option and it is far more convenient then a 3-point system as most implements can be hooked up or unhooked without getting off the tractor, however, that would not be the case for a PTO mower due to connecting or dis-connecting the drive shaft from the tractor PTO. I have several different 2 point fast hitch implements and find them very easy to attach to the tractor which makes the Super C my most utilized smaller tractor. Hope your Super C works out fine for your needs and I live in Rolla if you need to visually see a tractor with a complete fast hitch system from the factory, Hal.
