Super C Hydraulics
lbm
I am wanting to add a hydraulic remote to run cylinder lift implements, with my super c. I have looked around locally to find one with this set up but unable to find one. Any help and guidence would be greatly appreciated.
You need the block that will go on the rockshaft housing and the tubes coming from the pump will bolt to it. Then you can run lines out to the control valve you are adding. Depending on what cycl you plan on using you will need to add more storage for hy fluid. I have a block i would sell. send e-mail if interested.
If you don't have Fast-Hitch, find a SC, 200 or maybe a 230 with F-H in a salvage and get the parts for the F-H control. If you already have F-H, you can cap off the F-H cylinder and plumb into those lines. I think IH even made a solid rod to replace the cylinder if you can find or make one.
The tractor does have a fast hitch. I won't be able to use the hitch if I use it this way, right ?
(quoted from post at 17:00:39 01/03/10) The tractor does have a fast hitch. I won't be able to use the hitch if I use it this way, right ?
That's right, you won't be able to use them both at the same time. I'm sure there is a way to tap into the system and operate both at the same time, but I'm not familiar with how this circuit works. I do know you could put a flow divider off the pressure line of the pump (I have seen these at TSC) and then add an open center 4-way valve. However, this will always rob flow from the existing system and slow everything down... you probably don't want that. If there is a way to add it to the existing system without the flow divider, that would be better. What you would need is a valve to parallel the Fast-Hitch valve.
I have a 200 with a FH and another valve I use for loader or one way cyl. I had to install a blk between the FH valve and the Touch control. I have seen the blks on this sight before.
