Super C is stalling
JohnV2000
So here is the story. Yesterday I drove my Super C for a while and it ran very well, even climbed up a small hill in 4th gear, it sounded very strong.
Today, I started it up and drove it around for maybe 10 minutes, and then when I tried to go up the same hill I went up yesterday, this time in 1st gear, the tractor started sputtering and then stalled out halfway up the hill. It started right back up but was sputtering again. Eventually I was able to get it up the hill and back to my house, but it was running very rough and was sputtering and stalling out whenever under load.
Any ideas? Personally, I think the issue is with my carburetor because I noticed it leaks a little. However, I do not know, it could be an issue with the fuel line, and whatever it is, I would not know how to fix it.
Thanks,
John
Have you cleaned out the gas tank since you
bought the tractor? Going up a hill could swish the
gas around in the tank, and stir up some nasty gunk
that had settled out . I think I would start by looking
at the screen in the sediment bowl, also how well
does the gas flow from the tank. If that is good, see
how the flow is to the carburetor.
There is a drain plug in the bottom of the carb. With the gas turned on full at the tank, take that
plug out and catch the gasoline in a coffee can. In one minute it should make more than a pint of
fuel. If it starte coming out fast, then slows, the issue is supply, not the carb. There is a
strainer in the sediment bowl, and another at the carb inlet fitting. Jim
Time to do some basic diagnostics.
Always diagnose before taking action! Lots of people start throwing parts at it first. All that does is waste money and complicate the diagnosis.
Chances are you have either an ignition or fuel delivery problem.
Take a look at the spark plugs. They should be gaped at .025", should be a light tan color, not sticky black, or bridged with carbon.
Next take a look inside the distributor. Look at the condition of the points. They should be relatively flat across the contact area, a clean gray color, with no black/blue heat discoloration. Check the gap, with the rub block on top of one of the shaft lobes, the gap should be .020".
Check the centrifugal advance, the rotor should turn a few degrees one way, and spring back when released.
Check the shaft for side play. It should have very little play, any side movement will cause the point gap to change. If the bushings are worn, a rebuilt distributor will be needed, or convert it to electronic ignition. The conversion kit will work with a worn distributor.
Finally, check the spark quality at the plug end of each wire. You can make a spark tester with an old spark plug. Bend the electrode back or break it off. Remove one wire at a time, attach the tester to the plug wire, lay the base against something metal for a ground. Start the engine and watch the spark. It should have a strong blue spark across the test plug. Repeat for each wire. If any are weak or no spark, revisit the distributor. Look at the inside of the cap for carbon tracking, check the rotor, check the center post for good contact. Look at each plug wire, if carbon wires they may be bad, wire wires can have failing insulation.
Once the ignition system is satisfactory, go to the fuel system. Important to do it in that order, ignition first, then fuel. You don't want to be testing for spark with fuel spilling!
There is a small pipe plug in the bottom of the carb bowl. With the engine off, fuel valve on, remove the plug, be ready to catch the flow in a clean glass. There should be a full flow, then slow as the bowl empties out, but continue to trickle, not slow to a stop or drip.
Look at what was caught. If it's cloudy or water on the bottom, if dirty, rust chunks, the same will be in the tank and in the carb bowl. It will need the tank removed and rinsed out with E85 if you can find it.
The carb is simple, don't be afraid of it. Usually they can be taken off, eased apart, cleaned up and good to go. Just work over a clean area so anything dropped can be found. Take your time, take pictures. There are procedures, parts views, theory of operation on the web.
If you don't get good flow, take the fuel line loose from the carb. There are generally 3 screen filters on a gravity system. A screen inside the tank, a screen above the water separator bowl, and a screen inside the inlet fitting at the carb. Be sure all are clean and free flowing before blaming the carb itself. If an inline filter has been added, that could be the problem. Inline filters generally don't work well with gravity systems, too restrictive. If you want to use an inline filter, be prepared to change it often.
Hope this helps. Take your time, use your resources. Lots of Youtube videos how to do carb work, ignition tune up, etc.
You can do this, these old tractors were designed to be field serviceable with basic tools and basic mechanical knowledge. Part of the satisfaction of having one is to be able to do your own work. Be very careful trying to hire anything done on it. Chances are any dealership will turn their nose up at it, or turn it over to the worst mechanic in the shop that has no clue if the computer won't connect to it!
Let us know, keep asking, keep knocking, we'll walk you through it!
I ran out of gas on my Farmall C going up a hill. Fuel went to the back of the tank.
The old tractors are easy to work on. Either you have a spark issue or a fuel issue. Those are the first
things you should check before you ask for help.
Contaminated fuel is common with old rusty gas tanks, dirt and water getting into fuel.
Points, condenser, distributor cap, rotor, bad plugs, plug wires and water are all common problems with
ignition on old tractors .
Thank you everyone, I will try and diagnose the issue tomorrow when I have some time after high school graduation practice (yes, we have practice for graduation, haha).
I sort of feel stupid asking such basic troubleshooting questions, especially when to most of you it is obvious to try certain tests first, but to me, I do not even know where to start so I need to ask for help. Hopefully soon enough I will become an expert as well!
I tried to use the drain plug on the carburetor, and when I first opened it, it gushed gas everywhere, but then it slowed down. I had a hard time catching the gas in a glass jar because of where the drain plug was located, and some of the gas ran along the outside of the carburetor and dripped elsewhere beside directly out of the drain plug. What was a I doing wrong?
I drove the tractor again today, it ran fine on the flats, full throttle in 3rd gear no problem. However, it seemed to sputter more than usual when letting off the clutch to go into 3rd gear when stopped. Also, when climbing up a small hill it almost completely stalled, I had to take it out of gear to prevent it from stalling the engine completely.
