Super C oil filter
What way is the correct way to install the engine oil filter? One end has a longer,tapered nipple and the other end has a shorter nipple with a seal in it. It seems to fit both ways. I'm using a NAPA 1172 filter. This tractor had a spin-on kit and I'm putting it back to original.
The way I've always looked at it the tapered end was made to fit down into the casing so oil didn't get past it. Right or wrong that's the way I put them in.
The large tapered end goes down.Dont forget to dig out the old hard gasket. You will probably need a chisel,or something to did with.Do you want to sell the spin on kit? Pictures?
