Super C oil leak
MarkinMo1
Hello guys I have another question on the front seal removal. I am getting ready to take the governor off and was wondering if anything I should be aware of. Will springs go flying? Thank you. Stay tuned I will update how my progress goes plus more ?'s
Since I have no history to compare this is what I discovered on my Farmall c.
Spring could be be broke inside the Governor shaft .
The trust bearing ball bearing s could come out of the carrier and end up inside bolster , mine did. . Figure out how to catch them or order a 70 dollar bearing from Steiner , I didnt look if yesterdays sell them .
A few issues when removal
You got to remove the radiator and the steering pedestal to get the damper pulley off then you can remove the gov and there are parts there easy to lose but wait till everything else is removed will make removing the gov so much easier
