Super C Planter + parts
Deano4863
Please help me identify the implements that I got with a Super C. Pictures are posted on the implement forum. Thanks
You should've put them on here. Hal
i see a planter and enough parts to make a front cultivator (possibly 2 styles), and a rear drawbar.
karl f
I can't tell much about the planter but that drawbar in the foreground of your photo's appears to be the correct one for a SC fast hitch tractor. They are not really that easy to find when looking for one but I did find a NOS one at a RPRU a few years ago in Mansfield, Ohio. If your tractor has a fast hitch that would be the moveable drawbar for the tractor, Hal.
I am not sure but take a look at the photos of the one I have. They are close. I have one that is similar but mine is mounted on the tractor yours looks like may be tool bar mounted? Mine is a C-279 blackland planter. There are several listers with a simular configuration. I'll drag out my book's and see if I can come close to an ID on yours.
C 279 Blackland planter
Did not see the photos, but we had a set that worked on a C/200. Dad bought the planters in 1954 for a C then used the same set on new 200. I have a set that were originally used on a C that I now use on a 200 (required a slight modification to the chain drive). I will be mounting them this spring to plant my garden, so I could post the pictures.
