super c rear tilller
coey d
rear tiller project, works good just need to slow tractor down. If I had a super granny low in 1st it would be just right.
and a narrower tractor , as you will be packing it again with one tire. it don't look like you can narrow it enough.
Put a gear box between the belt pulley output shaft, and the planter drive shaft sticking out from the right hand brake
housing. Geared correctly, it would go as slow as your geared it. Jim
I've got the same tiller for my Ariens garden tractor. They work the best at around .5 to 1 mph. Keep in mind that this isn't the strongest design for a tiller since the tine shaft is
held only in the center with closely-spaced bearings and you have more than enough tractor to completely destroy it. In harder ground you could take the extension off the left side to
reduce the load on the bearings. In soft ground you can actually run with two extensions, one on each side (like my tiller is equipped), so you might keep your eyes open for another one.
With extensions on both sides a person does need to be careful with what they ask the tiller to do, though.
You will not like the way it sets. If you got a set of shorter tires it would slow you down some. Put a set of hubs on the axles then you could put whatever size you wanted to.
(quoted from post at 14:33:35 03/12/20) If you move your wheels in you'll cover six feet, that's what my blade and plow are.
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto8201.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto8202.jpg">
could you send me some more pictures of your front blade design, on how it lifts, thanks
It's a genuine IH blade minus the proper lift linkage, was on the tractor when I bought it. The chains hook to the rockshafts, probably not ideal but I've been using it for about 28 years.
