Hi,
I just got my Super C charging again but it is with my original voltage regulator. The main problem was an incorrect generator belt (too long).
I recently purchased a new/old stock Delco regulator and when that part was installed it did not charge. It's possible that the new part could be bad or it was a return or even an incorrect part.
The part on the box is 1118982. The part looks correct.
Anyhow, the problem with this regulator could simply be the setting of the points.
Does anyone know an approximate feeler gauge thickness to achieve around 7.5 v charging voltage? Also, is there a setting for for the second coil to determine the charging current?
What is the correct charge current. Anyone know the resistor value on the back of the unit?
I also have an aftermarket regulator that I need to check and see if it works - maybe it also needs the point gap adjusted.
The Super C has a Delco generator and has a water pump.
Thanks,
Mike Uschak
This post was edited by mu2 on 05/15/2022 at 08:42 am.
Thanks,
Mike Uschak
