super c with hicups
nc super c 1
have a super c that hicups while the lift is in raised position touchcontrol has hy-trans in it and is full.the control value on side of touchcontrol leaks some have replaced the seal in the top what could be the problem? john
You need to determine if leak is in cyl or check valve. With hitch raised, load on it, engine shut off, see if the hose on rod end of cyl(which is not supporting the load) has pressure in it, if it does your cyl is leaking. May require unhooking hoses to determine. If oil comes out of that hose, cyl leak. If oil actually lowers in hose, check valve is leaking. Just be sure you check correct hose as of course the one to lower end of cyl will have pressure.
