Yes it will there is a cut-out for the starter which goes in from the front and will leave a void on the bell housing but thats not important, Ive seen it done several The engine you are looking does it have the place for the pump. The crank mite not be drilled for a pilot bearing. I talked to one owner and he drilled it with an electric hand held drill. I would use use a Millwauke mag one if i was to do it. good luck.
