Super Dextra
Dog94
I have a Super Dextra Tractor probably a early 60's model. It will will start and run, but when it is put in gear and the clutch is let out it will not move backward or forward in high or low range. The hydraulics work fine Any information would be appreciated.
I too have a 1963 Super Dexta that I bought new in Nov. 1963. While picking corn shortly after,and being unfamiliar with the new-fangled differential lock, I panicked and engaged the diff-lock at pto speed. Tractor would not go into any gear ...........panic!!!!
Turned out that I had broken a small coupling in the transmission (about 4"long) and repair was both easy and inexpensive (at the time). Sorry I can't be more specific as to what that coupling is called as I was very young at that time. Hope this helps as you've got a very good tractor there.
Jim
