Super H Hyd Pump
Michigan Bob
My Super H has an M&W hyd pump (I think that's what it is)running off the distribtor drive giving it live power. It also runs the power steering. When I start the tractor it takes a while for it to start working. My tractor also has a Horn loader that has been on it for a long time. I have changed the oil and bleed lines, but it still does have much pop. Are parts avilable for rebuild? Is that something I could do myself without specail tools? Also the distibtor sits verticle and the coil sits verticle too. The other tractots I've looked at have the the distibutor and coil horizontial. Is that customary with this install. The other tractors I've seen have a horizonal placement.
The vertical Distributor was a aftermarket application often replacing a Magneto. Sometimes it was used as a method of putting hydraulic options between the front cover and the oil filter housing. JimN
Thanks for the info. The pump sits right there and is larger then most other pumps that I've seen on other tractors. I hope parts are still available.
