Super H piston?
D Slater
Knew a fellow once who run a standard piston on C-164 SH blocks with sleeves removed with little work. From what I remember they were for a older GM truck engine and 3-11/16 or little bigger diameter.
Anyone have a idea on what pistons they were?
theyd have to have a 2.5 compression height or within .100 with a small pin n offset the pin bore to raise or lower it to make it right.
A lot of pullers I know run a 301 IH piston in the SH & 350 block. I have also herd of the use of the 305 V6 GMC piston.
