super h power steering
If (and only if) the trastor has live hydraulics. THis means there is a pump mounted in front of the distributor. this system can provide enough volume and pressure. it will need an adjustable priority valve to provide pressure to the steering ahead of all other uses. If it has a belly pump, it is not appropriate because the steering would loose power when the clutch is pushed in. Jim
Then it will power a steering motor, BUT not from an "outlet."
The steering has to be powered from the main hydraulic loop, the pressure line running from the pump to the hydraulic system. You will need to install a priority valve there to send approximately 3GPM to the steering, and the remainder on to the hydraulic system, whatever that may be.
Thx, That is what I will do. I will put the priority valve in the hyd line from the pump to the hyd unit and plumb the hyd fluid to the PS
unit. I don't have other hyd uses so the use of this hyd pressure should not be an issue. My only issue is securing all the fittings I need
for the plumbing.
