Super M hunting
Hello, posted a while ago, finally got to checking some suggestions from earlier post.
I opened the top breather cap on governor and watched the shaft ( you can see in the video ), its moving at a steady throttle position.
If I hold it steady with my fingers, engine evens out.
What is next step?
Choke helped, so I adjusted idle air screw and issue seemed to clear up. Concern is the idle air screw is all the way in.
Thoughts?
