Super M Speedi Sleeves
Hello all. I'm working on my Super M and need the part numbers for the speedi sleeves that fit the parts in the pic. One is the one connected to the clutch shaft. The other slotted one drives the belly pump. But all you great people know this.. As you can see, the parts are heavily scored from thousands of hours of use. I know the parts are available new, but some are pricey. Any help is much appreciated..... Darryl
NAPA auto also sells Speedi-Sleeves over the counter and online. They might be higher priced but more conveniently located locally.
Measure them to the nearest .001 inch to determine the size you need.
Is there an oil seal that goes over those shafts? If that is the case the seal will have a speedi-sleeve corresponding number.
I just bought a speedi-sleeve for the PTO shaft on my Farmall C. The SKF seal number is 13865 and on the box it says use speedi-sleeve 99138 for shaft sizes 1.371 to 1.377. Ask your local bearing and bolt supplier for the correct sleeve for your particular application and shaft size. BTW, they are great and solve a lot of problems.
Tried to use a speedy sleeve in a Farmall C pesco pump, didnt work , I didnt have the Machine tools to do necessary turning and boring. But it would have worked dont fit me wrong with measurements and correct sleeve. Instead
I polished shafts and use oversized nitrile o ring from McMaster Carr. Sealed leak and passed wheel weight lift test with with high pressure gage on line was normal.
Without measurement I dont know what to reccommed to you .
