Super M won't take throttle
RickW
i have a Super M puller with around 400 cubes. I have pulled it for 2 years and never had a problem. Now it sputters when you give it the gas quickly or when the govenors kick in. I have replace the plugs, the spark plug wires, the coil and have put another carb off of a 450 on it and nothing has changed. if you give it the gas slowly, it will run wide open perfectly. I also put a new distributer cap on it. It has an electronic ignition, no points. I have missed most of the season and need to get to pulling again.
Check for fuel flow. Sounds like there is a blockage somewhere. Look inside the tank make sure it's clean. I once found a clear plastic wrap off a cigg pack in one,talk about a sob to find!
is the float stuck in the down position I had a similar issue and the float was hitting the bowl causing that exact same thing to happen
(quoted from post at 16:00:52 07/24/11) i have a Super M puller with around 400 cubes. I have pulled it for 2 years and never had a problem. Now it sputters when you give it the gas quickly or when the govenors kick in. I have replace the plugs, the spark plug wires, the coil and have put another carb off of a 450 on it and nothing has changed. if you give it the gas slowly, it will run wide open perfectly. I also put a new distributer cap on it. It has an electronic ignition, no points. I have missed most of the season and need to get to pulling again.
Have you checked for vacuum leaks? Could be time to replace that manifold gasket.
(quoted from post at 18:20:53 07/26/11) water?
While I do not claim any degree of knowledge about Farmall I do know that the main fuel passages have to be increased in the carb to handle that much bore. I can see how a stock carb off another tractor would not have enough fuel flow through the main metering circuit and would give the same symptoms. If I recall correctly there was a procedure which was done to the carb when even a simple M&W overbore was done let alone a major increase like you are talking. There are good IH builders on this forum who can help you, keep asking. mEl
Someone sent me an e-mail advising me to close the gap on my plugs and it cured the problem for now. I plan to install a MSD box today to help correct the problem so that i can open the gap back up on my plugs. Thanks to all for the great suggestions and your assistance in this. I really do appreciate all of the serious replies that i recieved.
