here my question
have a super m i only use push snow with maybe couple times in summer for odd jobs but most part just set inside
have noticed that oil will run out of blow by going up hill are the returns plugged if so what could i do
also the rear main seal is leaking my guess dried out anything i could use to help it with out replacing
Blowby and gook leaving the blowby tube on a tractor used lightly and in cold weather is accumulated moisture. Work the engine HARD an hour two in warm weather - if the engine's in good shape it will gradually disappear.
To the oil leak you sure it is the rear main? Frequently it is transmission oil leaking from a bad input shaft seal. Or from the belly pump drive if it's a Stage 1 SM. Simple and inexpensive to replace both seals without splitting the tractor (I've done several).
Suggest dropping the dust cover beneath the clutch and see exactly where the oil is coming from...
