Super MTA hydraulic pump
super350
I've read some past posts about buying a hydraulic pump seal kit for an MTA and their lack of availability. I haven't found anything updated. Does anyone know who carries a seal kit? Also, was there more than one style of pump put in an MTA? If so, how do I know which pump I have. I found some numbers on the front of the pump(facing the distributer) but nothing that resembles an IH part number. If anyone can help me out I'd appreciate it. I have oil leaking into the distributor.
There were 2 different pumps available on SMTA I believe. An M&W and international. If you check parts book it shows how each one looks so you can tell what you have. I don't believe thy have a parts breakdown on the pumps. I have put new front and rear seals in mine, it is an IH pump. The last time I replaced the pump with one I ordered from this site and it seems to work good.
My old paper parts manual for super m shows only one pump for gas tractor and
of course different number pump for Diesel tractor. It also shows same repair
kit for each pump. It lists pump for gas as Presco and for diesel as pesco.
I never heard of a Presco but saw plenty Pesco pumps so wonder if that is
misprint.
The mfg number for the gasoline tractor hydraulic pump is 05-2168-030-02.
IH number is 357214R92.
Seal kit number was 356999R91.
All number obsolete of course and most likely been replaced at one time or
another but I put in a number of those or similar kits over the years.
For just the shaft seals a non IH site showed that
356887R91 is the seal. This was shown on a breakdown
for a 400, thats number is not available from CNHI. The
other site gave a supeceeding part of 124633R91, that is
an available seal from CNHI at $16.50 each. On the CNHI
online parts, it shows this seal and if you click view more
under ..Fitment.. it shows Super MTA, see
link. All info worthy of the price you are paying, double
check yourself it is your money. Getting seals
by size comparison would likely be cheaper.
Seal at CNHI parts site
Yesterdays Tractors sells a pump similar to the one you are working on. Call the tech department
and see if the pump they sell has a re-seal kit. If so, order one and see if it is similar to the pump
seals you have. Im sure they would take it back if you didnt open the package, if they do offer
such a thing.
Used to tell what pump by the body shape. With all the replacements now I don't know if it holds true. First picture
is a Pesco. First type IH used on SM and W-6 before that. Second picture is a Thompson.
Pretty sure they quit selling these kits long ago. At one time a seal kit was also sold for both pumps. Last one I
had was 362331R93 for a Thompson.
