super88 hydraulics
super99
I posted earlier about mounting a Woods L306 belly mower on my super 88. I got it on and it was set up with a short one way cylinder. The right side was set up for 2 way so I tried to use the left side for the one way, I was told to add a hose from the return line if it was set up for 2 way to the drain on the hydraulic unit. That didn't work at all. Finally moved the right side couplers to the front, hooked up the hose for the cylinder base to the one way cylinder and tried it. Works just like it should without a momentairy restrictor, I'm confused but happy. Only issue now is the drive belt wants to run sideways in the drive pulley.
