Supertech Tractor Hydraulic Transmission
JimStr
Hello,
looking for a little help. i need to do a hydraulic change. I picked up this utf from walmart. is this a new grade, does it work for my 8N?
(quoted from post at 08:52:05 08/12/22) I see M2C-143 but not 134. Please explain for someone not very educated in those numbers.
Probably a typo. M2C143 is a PAO lubricating oil and has nothing to do with a UTTO.
Bottom line is it is a generic UTTO and will work just fine.
TOH
This post was edited by TheOldHokie on 08/12/2022 at 01:58 pm.
The reason I made my comment is that I looked at the other specs and they were the same as the ones on my bucket from TSC. If this oil meets the other specs,it'll meet the Ford specs.
(quoted from post at 14:33:18 08/13/22) The reason I made my comment is that I looked at the other specs and they were the same as the ones on my bucket from TSC. If this oil meets the other specs,it'll meet the Ford specs.
The list says it is suitable for use in applications calling for a specific specification. It does not say the fluid meets ANY of those specifications and in fact it can't.
For example it lists both Ford M4862A and M4862B. M4862A is a mild EP vgrade 80 gear oil and M4862B is a grade 90 oil. Can't be both.
As I said - its a generic UTTO (GL4 gear oil and probably viscosity grade 80) and will work in a Ford tractor common sump.
Dan
This post was edited by TheOldHokie on 08/13/2022 at 01:38 pm.
