Supplier for block mounting bolts
E Needs
I'm working on a 1940 B and several of the studs where the block mounts onto the main case need replaced. Does anyone know of an aftermarket vendor for these? I think the part number is B1333R but I'm not sure.
Hard to find the proper made studs anywhere but JD. The one end has larger dia. threads that lock them into place.
When I needed something like that I would take some out of another tractor that was for parts. Double nuts on them you can usually get them out without damage.
