Sure Seal instalation tool
Doug-Ohio
Ever install a Sure Seal? Fun huh? After wasting an hour failing to install one and ruining one in the process I made this:
First try at posting an image. Hope it worked.
Anyway, worked slicker'n snot.
(quoted from post at 14:55:00 04/13/09) Ever install a Sure Seal? Fun huh? After wasting an hour failing to install one and ruining one in the process I made this:
Anyway, worked slicker'n snot.[/quote]
[img:3caa977e8e]http://i689.photobucket.com/albums/vv258/dtoman/Suresealtool.jpg
(quoted from post at 15:01:13 04/13/09) Phooey. Just the link, no photo. What did I do wrong?
It appears that you are trying to use BB Code on the classic forum, you have to use HTML code there.
You can use BB Code on the modern forum.
You also dont need anything after the .jpg in the URL.
Doug That looks neat, wish I would have had it back in early March when I did mine. I know what you mean about them being frustrating . Thanks for the picture
Larry
I installed them by buffing the leading edge of the seal to remove burrs, and using a 28 inch length of about 2.5 inch PVC pipe to slide over the axle. Placed a wood block on the PVC and tapped it down with a 2 pound hammer. Easy!!!
