Nute
Decided today to replace the old leaky PTO seal and this is what I found. Anyone seen this before? Doesn't make any noises or grinding, then again maybe thats cause it's half gone now.
When I took it apart both snap rings were in place where they should have been. Just bought this N about 3 months ago and needed to change the fluid and this is how I found it. It seems to be close to the diffy, not sure though this is my first tractor.
did you find any old rings in the sump after pulling the shaft? somethings been riding there!
OR.. it was broke and welded and ground down?
soundguy
Nothing in the sump. Cleaned it all out today. I'll go for the broke and welded option. Maybe I'll just go ahead and replace it while I got the fluid out.
[b:a98461c293][i:a98461c293]
Just goes to show...that a picture is worth a thousand words.
And another JMOR pic., goes to the info file!!!!! 8)
Thanks Jesse.
Gary :) [/i:a98461c293][/b:a98461c293]
(quoted from post at 10:05:42 05/22/09) [b:3599b5076d][i:3599b5076d]
Thanks Jesse.
Gary :) [/i:3599b5076d][/b:3599b5076d]
ish we could thank who ever it was stolen from, but.........?
If it is un-protected on the Internet, I call it 'available'!
(quoted from post at 09:12:15 05/22/09)
(quoted from post at 10:05:42 05/22/09) [b:15f6101898][i:15f6101898]
Thanks Jesse.
Gary :) [/i:15f6101898][/b:15f6101898]
Weellll.....I don't call that stealing......I call it passing info. on to others!!!! :lol:
BTW: I concider myself an...."OTHERS"
Gary :D [/i:15f6101898][/b:15f6101898]
the turned down spot on the PTO shaft.
Is for A steady rest to ride on, while the shaft is being turned between centers in a lathe.
the steady rest is to keep the chatter out.
It is only there for the machining process.
in other words it is made that way.
