Geo-TH,In
SV. Here's my prototype front blade. Need more weight. Planning to replace wood with 1 /4 inch plate and weld 3 inch pipe where you see plastic pipe.
All I need is good weather because my welding booth is a clear blue sky, a warm day and no wind.
George
I assume this is for snow. Seems like you'd want to use a much smaller pipe for the bottom- 1 inch or so. Wouldn't the 3 inch just slide up and over the snow?
I like to leave a
Little snow and gravel behind.
A 3 inch pipe works.
A 4 inch pipe works better.
Sun melts any snow left behind.
Only works on fresh wet snow. Doesn't work on snow ice mix.
George
Welding a pipe should prevent bending. May need to weld angle on top.
Metal should be stronger than wood.
Wood has worked here for last 10 years.
How does the pc pipe hold up? I have been thinking of splitting one length wise to put over the Meyer blade on my trcuk for plowing my dirt drive. Too easy to move too much dirt with just the blade with its wear bar.
PC pipe has held up for 10 years on Farmall . 6 of those years had no snow to push. I'm sure if I ran into a tree or a post it may need replaced. I'm just pushing SNOW, not rock.
????? Do you have anything attached to the back of the tractor? Why not just put a blade on the back, turned around to push going backward? I've been doing that for 20 years with a Kubota, no less. That gives you the best of both worlds. A blade on the back and a bucket on the front. Both very useful when it comes to moving snow. Another option would be a snow blower on the back with the bucket on the front. I prefer a blade to a blower. Why? I've been using a blade for 20 years with absolutely no maintenance whatsoever and it'll be good for another 20. I don't know how many blowers I would have been through by now. And endless repairing. And, I don't buy the argument: "I get a stiff neck looking backward". Today's tractors have swivel seats , heated cabs with good vision, etc. I'm almost 84 and still do it with an open station tractor and, dressed properly, can plow all the snow that comes my way.
George I like some of your ideas but definitely not that one. I do have an 8 foot blade that attaches to the bucket but I don't use it much, I can take it on and off in a minute or 2, but I mostly use a 7 foot rear blade. Like Bill Wis say's the best of both worlds you can stack snow high with the bucket and move it any where you want. My Son has a power angle plow he uses on his Mahindra but it is on a quick hitch so you take the bucket off and put the plow on or the Grapple.
I want to use both front and back blade at same time. Sometimes its easier to pull in drive and lower front blade and back out. Sometimes the back blade leaves SNOW behind and from blade can remove that on the return pass.
Guess one needs to operate something to understand why I do what I do.
George
In 69 there was a 7 inch. I told the mechanics at Doan and Decker that I was driving down town for restaurant food, if they wanted to come. 2 said sure (as a joke!!) I was driving a 1960 Saab 3 cylinder 2 stroke car with 5.00 16 tires on it. It was no issue at all. we drove past 50 stuck or abandoned stuck cars in that 1/2 mile. sometimes going into the oncoming lane (no traffic) never spun a tire. They were pickup truck and pinto types. It blew them into a different mindset. It also was a discussion topic when we drove back into the lot on time. Jim
Same deal with the older VW Beatle bugs. Had the narrow tires. Those tires would cut through snow and act like self centering rudders. Really impressive are those Subaru all wheel drives. As long as they don't get belly hung up on really deep snow they are quite impressive.
Looks good should handle what you are wanting to do with it . Until I put that dozer on my 3020 I never knew how much better pushing snow forward is than trying to go in reverse for ten hours a day not because of the stiff neck but because I can push a lot more going forward than reverse
Geo, always like your creative ideas. Just a thought, what about installing gauge wheels on each side of the loader bucket. Just set the height you want and use the loader bucket to push the snow.
It sure is not anything that I would consider building even out of good suitable steel. If I made a blade it would be mounted directly to the boom with bucket off.----Loren
